Forum Home Forum Home » Club Nissan Forums » General Car & Club Related Chat
  New Posts New Posts RSS Feed - Two questions about the Nissan Note
 Post Reply Post Reply Page  123>
£5 Note View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote £5 Note Quote  Post ReplyReply Direct Link To This Post Topic: Two questions about the Nissan Note
    Posted: 11 December 2009 at 16:03
Hi Guys,
I can't find my Owner's manual for our car and could use a little help from the clever types here.
How do I adjust the clock?
It has been an hour fast ever since the clocks went forward, lol
Also, about the sat/nav system, can I somehow make it so that Speed cameras show up?
Cheers for any info.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote £5 Note Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 04:43
OK, Is there a better place to ask than here?
MATT GT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MATT GT Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 10:58
Hi.
Can help with clock issue but not sure on speed camera on sat nav.
Next to the clock display is a small knob. Press and hold for 3 seconds or more until the display starts to flash. Once flashing each press on the knob will change the hours, when reached the correct time don't press anything eles it will automatically set.
Hope that helps.
Matt
Daf_newport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daf_newport Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 11:12
Hi,
The first question's relatively easy. If you press the setup button, it should be in there somewhere for how to change the clock. Just have a play about with it as you can always restore it to factory settings.
Maybe look for a download of the user manual online? (should be able to find a free version somewhere I think?)
Not sure how to make the speed cameras show up, sorry. Perhaps contact Nissan customer services from their website?
Hope that helps?
Daf...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 19:15
set the clock as above
you need to add the speed camera poi (point of intrest) to the sd card
download a poi set
insert the sd card into a card reader on the pc, drag and drop the files onto the card
stick it back in the satnav unit and select poi and scroll down the list
iirc there a correct way to install poi............. got a link somewhere....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 19:18
hope this helps, this is another way of installing poi on the nissan connect.................... with a usb memory stick/pendrive
http://www.pocketgpsworld.com/uksafetycameras-nissan-connect .php
Post Options Post Options   Thanks (0) Thanks(0)   Quote £5 Note Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 19:34
Matt ... Ta for the reply but we may be thinking of different clocks here. Mine is a digital one at the top right of the central Screen that the Sat/Nav uses. There is no little button anywhere near it.
OK, this is where I get to look really stupid.
"setup button" ...??
**Looks confused**
What Setup button?
I can find the Info button to view all the computer trip stuff.
Whereabouts am I meant to be looking?
Re the Safety camera stuff, the pendrive version looks easy enough (famous last words) but I can always revert to the other option if it all goes wrong.
Ta very much.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2009 at 20:04
the clock on the connect, you can set it so it picks up the rds clock or set it manualy in the settings menu
have a play sure you will find it
Post Options Post Options   Thanks (0) Thanks(0)   Quote MATT GT Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2009 at 09:39
Sorry Was thinking of earlier Notes before connect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daf_newport Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2009 at 10:31
Originally posted by £5 Note £5 Note wrote:
"setup button" ...?? **Looks confused**
What Setup button?
Well, on mine it's on the right of the Connect's screen - next to the "map" and under the car symbols. See the picture in the link:
http://www.carkeys.co.uk/images/cm_images/nissan/note/nsnot0 23.jpg
Perhaps you've got a different version?
Daf...
This page was generated in 4.281 seconds.
