Forum Home Forum Home » Club Nissan Forums » General Car & Club Related Chat
  New Posts New Posts RSS Feed - Newbie questions
Newbie questions
collinsc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote collinsc Quote  Post ReplyReply Direct Link To This Post Topic: Newbie questions
    Posted: 14 August 2010 at 17:33
Hi
I have some newbie questions that i'd appreciate help
with.
I have a micra 1.0 2002.
1. How would i go about getting a spare key? and how much
would it cost?
2. What is the tyre pressure for a micra 1.0 2002.
3. How would i go about getting a replacement cap for the
water bottle?
4. Where could i get a rear wiper arm.
Guess 3/4 are a scrappy?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote crazytaxi Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2010 at 23:16
HI
Q.1 Spare key Q's have cropped up a few times, the best route seems to depend on the age of the car and to be honest i'm not sure about yours. Try takinf the key you've got to a good motor factors (motor world/land type places) if they can sort it it should be around the 40 quid or less price. Also timpsons can do the early ones not sure how much they charge.
 If it's the latter type, some have been able to buy blank keys from ebay and then get them cut and programmed. not sure how much it worked out for them.
Final option is going to the main dealers with a chair posistioned in a suitable place for you to fall into and a stiff drink for the shock, you will be talking well over the ton
Q.2 not sure, should be a sticjer on the drivers side near the door catch
Q.3/4 you answered yourself m8
Post Options Post Options   Thanks (0) Thanks(0)   Quote collinsc Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2010 at 17:22
cheers
DRIFTER View Drop Down
MR JOHNSON
Post Options Post Options   Thanks (0) Thanks(0)   Quote DRIFTER Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2010 at 16:43
depends on key type to
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2010 at 03:28
I think Micra tyre pressures are 33psi front and 29psi rear.
The rear wiper arms can be bought from Nissan or Renault and are about £12.
This page was generated in 2.906 seconds.
