Forum Home Forum Home » Model Specific » Primera
  New Posts New Posts RSS Feed - p11 benzine gauge problem HELP
micoz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote micoz Quote  Post ReplyReply Direct Link To This Post Topic: p11 benzine gauge problem HELP
    Posted: 17 April 2010 at 02:24
PRIMERA P11 benzine gauge false read out.tank was filled out full but it
shows sometimes correct;sometimes empty;sometimes quarter.fuel
sender in tank was tested and ok.
Gauge test made all gauges works fine.(i made this test by pressing
two of the hour and km buttons and holding while turning on and off
the car key.
Please help me at this way.and sorry for my english.
Car model primera 1.6 cc model year 2000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crazytaxi Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2010 at 17:26
Hello and welcome to CN, and you're english is better than my turkish. Personally i'd still suspect the sender unit, i know it has been tested but what's to say it wasnt tested at one of it's "sometimes correct" times?
regp11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote regp11 Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2010 at 23:33
Hello, I have a Primera P11-144 year 2000. I have the same problem, and not had a solution that worked. I changed the fuel gauge sensor in the tank. Also we checked the wires. We did the gauge test by pressing the two dashboard buttons and turning key off/on. Still the problem is there. Some people are now telling me it's an electronic problem and the instrument/clock panel needs to be replaced. I hope to hear from others with this problem and how they fixed it.
This page was generated in 6.000 seconds.
