  New Posts New Posts RSS Feed - r reg micra wont start! help!
hayleyallen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hayleyallen Quote  Post ReplyReply Direct Link To This Post Topic: r reg micra wont start! help!
    Posted: 11 November 2010 at 16:35
I have a 1998 1.0l nissan micra and it wont start in the
morning. once it is started it will run for the whole day
but leave it over night and the next morning i have the
same problem. sometimes it starts if i remove the fuse
that sends the petrol to the engine but recently this
hasnt been working and the battery keeps dying. my
mechanic friend took the spark plugs out and theyre
soaked with petrol suggesting there's too much petrol
getting there. ive changed the spark plugs, got the
sensor that is supposed to stop too much petrol getting
to the engine and also replaced the part that measures
the engine temp (i think, i didnt do this myself!) but i
dont know what else to do! ive already spent so much
money on it changing different parts. can someone please
heeelp!
lynall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 22:13
Crank sensor ecu cannot see engine turning so doesn't generate a
spark
Might be worth removing and seeing if any obvious damage
Lynall
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 22:16
Two on e bay looks like there are two types both under £10
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 22:20
that would make sence esp when starting from cold
Post Options Post Options   Thanks (0) Thanks(0)   Quote hayleyallen Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 22:41
thank you!! i shall try this, hopefully it will be the last
thing!
This page was generated in 3.688 seconds.
