  New Posts New Posts RSS Feed - micra fuel consumption
 Post Reply Post Reply Page  12>
Jaidee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaidee Quote  Post ReplyReply Direct Link To This Post Topic: micra fuel consumption
    Posted: 21 November 2010 at 14:08
Hi guys,
I currently own a nissan micra 1.0 1999 profile (i know what a beast!? not! lol). I always assumed that they had good fuel consumption but im only gettin 35mpg. I drive 10 miles a day, my car isnt loaded up and i stick at 60mph.
Is there anything you would recommend so i can get more miles for my money? or is this generally what i should expect?
Seeing as petrol prices are becoming even more rediculous any help or advice is greatly received!!!
Thank you!!
Jx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2010 at 17:32
Its about right for a 1.0 as you have to rev it to get it going.
A 1.1/1.2 may give better mpg
lynall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2010 at 21:55
My 1.2 is doing approx 42mpg to work and back 12 miles each
way, any decent run and its over 50mpg.
Mums got a 2001 1.0 and we worked hers out the other week
and its roughly the same as mine.
So if you are only doing short 5 miles trips 35 mpg is
probably not to far out.
Might be worth a decent service incl plugs and air filter.
Lynall
Edited by lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2010 at 09:05
Yesterday reset mpg on the dash drive to work and back carefully! trip
said 50 mpg, 12 mile trip roughly 7 miles in town other 5 miles 50mph
to 70 limit
So i got another 8 mpg just by taking my time quite impessed
Lynall
cringer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cringer Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2010 at 02:55
Had a 98 and currently a 2002 1.0 k11
and they both average me 40mpg
the older car was better all round and
was quicker though.
Wherever you may go there you will be
NOTEFEVER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2010 at 11:21
to 70 limit
Lynall
Trip computers are not (that) accurate..
Try to fill it up, drive it  a specific route and then re-fill it!
Then you can compare it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2010 at 19:22
You are right its now back to its usual 42mpg but i have
had to run the air con all the time to stop the
condensation.
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaidee Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 20:45
still doesnt look to be getting any better :( which is really infuriating as petrol keeps increasing and my fuel gauge keeps decreasing!
i guess ill check the tyres, and see if i can get it looked at. It had a full service and mot in august so im not sure why the fuel consumption is so crap, i dont think i could drive any more carefully!!!
Does the weather make a  difference?
 sorry clutching at straws as i have not a clue about cars, all i know is this isnt right!
any more suggestions guys?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2010 at 16:30
Did you Checked the Filters and the Injectors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2010 at 19:57
Yes cold weather will have an effect probably as much as
5% to 10%
Some peoples full service is not the same as others, ie
they may have just done oil and filter and maybe an air
filter but probably not spark plugs.
Fuel filter wont make any difference to fuel economy and
if it starts and idles fine the injectors are probably
okay.
I wouldnt try and drive it carefully as you are probably
lugging the engine at low revs which is wasting fuel.
As hard as it is ignore it and just drive it for a couple
of weeks and check again.
Lynall
This page was generated in 3.062 seconds.
