  New Posts New Posts RSS Feed - 98 and 2002 k11 speed
cringer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cringer Quote  Post ReplyReply Direct Link To This Post Topic: 98 and 2002 k11 speed
    Posted: 30 November 2010 at 03:02
Had a 98 1.0 k11 micra and currently
have a 02 k11 micra 1.0
the thing is the older car had a higher
top speed. It would cruise all day at 80
and would get up to 100 eventually.
The 02 i have now is much slower and
struggles between 70 and 80 and if im
doing 80 and i start going up hill it Will
struggle to maintain speeds of above 65
to 70?
Is this normal with newer k11 micra.s?
Are they less powerfully?
Wherever you may go there you will be
NOTEFEVER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2010 at 11:17
What is the mileage of both cars?
CG10DE
The 1.0 L (998cc) CG10DE was built from the introduction of the Nissan Micra K11 in January 1992 until it was replaced by the K12 series in 2002. The engine originally produced 55 PS or 60 PS (41 kW / 44 kW) @6000 rpm and 79 nm @4000 rpm. In 2000, Nissan removed the distributor and replaced it with coil packs.
according to wikipedia...
http://en.wikipedia.org/wiki/Nissan_CG_engine
CG10DE K11 March / Micra 1992–1999 1.0 L (998 cc) 71.0mm 63.0mm 9.5:1 58 PS (43 kW) @6000rpm 8.1 kg·m (79 N·m; 59 ft·lbf) @4000rpm DOHC, Multi Point Injection
CG10DE K11 March / Micra 2000–2002 1.0 L (998 cc) 71.0mm 63.0mm 9.8:1 60 PS (44 kW) @6000rpm 8.6 kg·m (84 N·m; 62 ft·lbf) @4000rpm
Maybe it has to do with the maintenanse..
Also there is (about) a 5% (acceptable) difference between
two (same) engines horsepower at this displacement.
Or check: catalyst, cables, spark plugs, filters, brakes, injectors, engines compression.
lynall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2010 at 19:25
Give it a good service then a good thrashing maybe its only
been used to potter around in all its life?
Whats the mileage of the old and new car?
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2010 at 21:14
iirc thay changed the gearboxes ratio in the face lift K11 1.0 is more geared to town work if your doing motorway work you ideally need at least a 1.1 - 1.3
FYI most police forces are dropping the speed thay prosecute at to around 92-95 MPH leading to a instant ban of 6-18 months
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2010 at 08:49
They wont nick you in a Micra as they wont believe their
radar gun
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2010 at 18:56
thay may do if its got a sr20det in it good for 400bhp if not more lol
This page was generated in 6.750 seconds.
