Forum Home Forum Home » Model Specific » Primera
  New Posts New Posts RSS Feed - problems
problems
revver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote revver Quote  Post ReplyReply Direct Link To This Post Topic: problems
    Posted: 21 November 2010 at 01:00
hi all got a couple of problems with my 98 p11 primera, 1 the heater only works  on the highest speed setting and i am getting a lot of movement from the gear stick when take my foot on and off the go go pedal? i saw a comment on here some time ago about the heater but can not find it now as for the gear stick problem could that be engine mounts wearing?  Big Smile
johnbr6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnbr6 Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2010 at 01:39
Hello there,
the heater problem is an easy fix. It is down to the
heator resistor card. It has simply stopped working.
A resistor card is the same in Micras(K11), Primeras (p10
and a P11 like yours), Almeras (N15) up to 2000 IIRC, a
tenner will get you a full working one from a scrapyard.
The gears wanting to pop out would be IIRC the rear
engine mount wearing, get it checked out from a garage.
I'm not mechanically minded, just read a lot of forums,
but I think what I've typed out are the symptons
Hope this helps.
Infiniti&Beyond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Infiniti&Beyond Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2010 at 22:08
just to add a bit extra, the heater resistor card is located under the glovebox on the passenger side, if you get down on your hands and knees and look upwards under the dash, you'll see a connector with a few wires coming from it and going to a piece of plastic thats held in with a couple of screws
gafcaf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gafcaf Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2011 at 03:09
about your gear stick,get under car to the centre and
you'll see a heat guard beside exhaust,take off heat
guard(4 screws i think)and check the little spring is not
broken,if it is try stretching back on ,if not replace -
this causes the gear stick to shake a lot when broken,only
takes 5 min to check or fix
Primera P11 2001 ,2.0 Tdi, 200,000 mls
Post Options Post Options   Thanks (0) Thanks(0)   Quote revver Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2011 at 13:10
Hi all thanks for info. replaced the heater card and pollen filter, car is due for mot so i took it for 2 new tyres and the garage bloke re-attatched spring behind heat shield but it seems that there is still some play in gear stick so will check the mounting. thanks.
This page was generated in 4.344 seconds.
