  New Posts New Posts RSS Feed - Wipers won’t stop!
Wipers won’t stop!
peterhopgood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterhopgood Quote  Post ReplyReply Direct Link To This Post Topic: Wipers won’t stop!
    Posted: 26 January 2011 at 17:58
Hi! I wonder if anyone can help? The wipers on my '53 plate micra will start up of their own accord whilst driving along, and won't stop, even though the switch is turned off! They will stop when the indicators are on, and when the rear washer is activated though!!
I have had it looked at, and the washer pump has been changed, the Body control unit connections cleaned, and the swich checked and the cabling inspected at the steering wheel junction (crock joint?)!!
Now the wipers don't seem to come by themselves when on normal driving, but will start up when the washer is activated, but then won't stop until the engine is turned off!! This is really driving me mad, as I hate it when wipers scrape over a dry screen!
Please help if you can!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2011 at 03:14
I pressume this is a new shape Micra (K12)
If so then try disconnecting the battery for 10 minutes as this will reset the control units and generally fixes a whole list of odd faults.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterhopgood Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2011 at 01:26
Very many thanks Mick! This had been driving me and my wife up the wall! Your tip did the trick! (Yes this was a new shape Micra)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2011 at 02:50
Glad i could help
rome_rod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rome_rod Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2011 at 03:46
+1
That was fast. Well done, mate. I had the same thing a while back. Disconnected the batt and wipers shut off. What I am curious is what triggered this behavior.
NOTEFEVER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2011 at 20:00
Could this, be caused from continuous exposure on humidity,
which somehow jams the unit?
I 've never heard it around my place...
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterhopgood Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2011 at 01:04
Oh dear, spoke too soon! I went for a longer drive today, down the motorway on a damp dirty road and after the fourth time of using the washer/wiper, it started working on its own again!!
Any ideas now?
This page was generated in 6.547 seconds.
