  New Posts New Posts RSS Feed - TEMP.GAUGE AND COOLING FAN
solo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote solo Quote  Post ReplyReply Direct Link To This Post Topic: TEMP.GAUGE AND COOLING FAN
    Posted: 17 February 2013 at 09:01
HI MY 05 2.5 PF TEMPERATURE GAUGE IS UP HALFWAY  AND FAN RUNNING ALL THE TIME EVEN THEN ENGINE IS COLD.
Ratchet View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2013 at 01:36
Evening,
Have you checked your coolant level?
Check these and top-up if needed.
Otherwise it maybe a faulty temperature sender unit and fan switch in the radiator.
Hope this helps.
Qualified ABC Diploma Level 1 & City & Guilds Level 2 Mechanic
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2013 at 00:08
Hi. It sounds to me like a faulty coolant temp sender unit. This used to be really common on Micras.
solo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote solo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2013 at 10:15
It was sensor. Thank you
This page was generated in 2.953 seconds.
