Forum Home Forum Home » Club Nissan Forums » Announcements and Help
  New Posts New Posts RSS Feed - sunroof help please
sunroof help please
harvey76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harvey76 Quote  Post ReplyReply Direct Link To This Post Topic: sunroof help please
    Posted: 16 May 2013 at 16:46
Please someone help I put the sunroof back on my primera gt and it would not close, got a friend to manually some how close it, but it doesn't open or close. there is power to the switch but nothing else happening , when he closed it manually he had to use the switch as well please
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 18:13
You will need to check if you have power at the motor. The switch operates as a relay so it may have power to it but there may be nothing coming out of it.
Did the roof go back without any noises?
Post Options Post Options   Thanks (0) Thanks(0)   Quote harvey76 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 19:43
it went back normal. then when I went to put it forward to close it it moved a bit then I clicked back and then it closed a bit more then refused to move at all, it was temperamental yesterday but closed eventually, if I take the motor out what do I look for, paul says when he had it he never really opened it fully just in the up position where it tilts. it wont open or close now, I checked the fuse 7.5 and its fine, all windows etc work,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 01:07
The sunroof fuse will not be 7.5 amp. It should be at least a 20 amp as the motors draw a lot of current. You need to unplug the motor and check for a live at the plug with the switch in the 'operated' position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 01:45
Harvey. I just thought i would let you know i havemade and uploaded a signature for you. If you don't like it let me know and i will remove it for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote harvey76 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 14:48
that's ok thanks with regards to sunroof I checked there is power to it I took the roof lining bits off to get to the motor and adjusted the plastic torque screw it worked for a bit then started making a loud gearing noise, think ill just buy another one , £4 from eBay lol. did Paul mention im limited to what I can access on here. been getting some quotes for both nearside doors to be filled and sprayed I cant believe how much its costing around £300 for pair,
DRIFTER View Drop Down
MR JOHNSON
Post Options Post Options   Thanks (0) Thanks(0)   Quote DRIFTER Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 21:12
Did littlleknocks email u back?
This page was generated in 6.438 seconds.
