  New Posts New Posts RSS Feed - water ingress in Micra
 Post Reply Post Reply Page  <123
mr.frosty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr.frosty Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2011 at 14:17
hi peggy,
an old test was to take out the carpets and dry everything off, sprinkle talc all over and go for a drive in the rain, the tracks left should show where the water is coming from.
hope it helps.
Peggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peggy Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2011 at 15:18
It sounds great, tks very much!
However, the water was in the body of the car under the floor. I can't see how I can do that . . . .
so far, it doesn't seem to have come back (let's keep fingers cross!)
Peggy
lynall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2011 at 20:09
Peggy 603 views says it all really!
Ive bought some dessicant crystals from e bay that turn
colour from orange to green when they absorb moisture.
After one night in the car they have started to turn
colour.
So for an experiment i turned the a/c off on the run to
work and the windows did start to mist in the rear but
nowhere near as bad as before.
E bay number 270682485429 maybe worth a go?
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2011 at 06:35
3 days later and car is still clear inside.
I have washed it for the first time in weeks plus the damp weather so it
would seem the crystals are doing a good job.
I'm quite pleased.
Lynall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peggy Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2011 at 10:22
might have a try myself, sounds good!
tks
Peggy
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynall Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2011 at 22:26
Washed it again and it did fog up again just on the screen,
so ran with a/c on to work and back and with a/c off its
been fine since.
The little crystals have turned dark from their initial
orange so are getting moisture from somewhere.
The two dark ones are now in the airing cupboard and are
slowly turning back to orange in the warmth.
Im happy car feels much nicer to drive with the a/c off.
Lynall
This page was generated in 5.334 seconds.
