  New Posts New Posts RSS Feed - Almera Headlights very dim
NoviceAlmera View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoviceAlmera Quote  Post ReplyReply Direct Link To This Post Topic: Almera Headlights very dim
    Posted: 09 December 2010 at 17:52
Hi, I've got a run of the mill 05 plate Almera 1.5ltr car. recently my dipped beams have been very dim. Does any have this problem. Doesn't seem to be a short or current leak. Took it to the garage and they think changing the whole headlight unit would cure the problem. I'm not too convinced as both sides are dim.
Thanks for any illumination.
Trev.
NOTEFEVER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2010 at 19:49
Sorry cause my English is not the best it could be...!
Do you mean that you have: blair headlights?
If so, they can be repaired but the won't last for too long..
Is the reflectors damaged?
I don't think you can disable the headlights, so no repairing available..
Check the circuits esp. the grounds before any replacements!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoviceAlmera Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2010 at 08:38
The housing unit looks OK. No crack or condensation. But the lens on both dipped beams looks slightly milky. Should they be clear?
Have cheked the grounding. Slight rust on one of the ground points. Cleaned it up, but didn't make much difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NOTEFEVER Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2010 at 13:47
There are some repairing kits (to do it yourself) for the lens.
It's gonna be "like the new one", but the won't last long...
Sooner or later they re going to need replacement...!
rmiddlemass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmiddlemass Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 13:31
Hi there
My car, 55 plate, also suffers from this same problem.
Sometimes I wonder if they are actually on! I intend to
purchase a pair of super-bright osrams (claim to be 50%
brighter) and try them. Will let you know
Regards
Ralph
This page was generated in 5.031 seconds.
