Forum Home Forum Home » Model Specific » Note
  New Posts New Posts RSS Feed - Peculiar noise
Peculiar noise
 Post Reply Post Reply Page  12>
DavidUK1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidUK1 Quote  Post ReplyReply Direct Link To This Post Topic: Peculiar noise
    Posted: 01 July 2011 at 17:12
My wife's Note has developed a peculiar noise, sort of a low hum when driving. It seems to be speed rather than engine related. I have jakced it up and had look underneath. Exhaust seems OK. All wheels turing freely not brakes sticking, no bearing noise ( I thought it might be  a wheel bearing) no significant play in dirve shafts. Drive belt looks ok.
If pushed I would say it is coming from the back of the car but it is difficult to tell becasue the low frequency makes it hard to tell.
Anyone any ideas?
Edited by DavidUK1
mdvineng View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvineng Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2011 at 19:30
check tyre pressures, as low pressure allows the tyres to deform more and that can create the noise. with low profile tyres a visible check is no good, you have to use a gauge, I've seen such tyres look OK but measure less than 15 psi.
both motorcycle wheels drifting with the power on feels great
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2011 at 22:02
hum from from the rear poss wheel bearings, jack the car up and grab the wheel at the top and bottom and see if theres any play do the same at the sides if in doubt whip the drums off and inspect
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidUK1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 01:15
Fair comment on the tyre pressures I will check those. Bearings already checked, I have trailers and am used to doing them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvineng Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2011 at 11:11
the other cause of tyre hum is a bulge in the side walls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidUK1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2011 at 18:11
Tyre pressure all within a 1lb or so of recommended pressure. I will have a look at the tyre walls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvineng Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2011 at 14:20
Also check to see if any balance weights have fallen off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidUK1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2011 at 15:37
I would expect dropped weights and bulges to exhibit a rythmic sound each time the wheel turned this is fairly constant low hum (like a wheelk bearing but they appear fine).
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvineng Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2011 at 15:57
That would seem true, so may be it is the wheel bearings. Do you know which side of the car it comes from, if so switch the wheels around and see if the symptoms follow suit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidUK1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2011 at 18:40
Local Garage has diagnosed rear wheel bearing. Maybe I didn't spin wheel fast enough to hear it because that was the first thing I looked at. There did not appear to be any play either. We will see if it has gone when I pick it up tomorrow.
Edited by DavidUK1
This page was generated in 5.234 seconds.
